Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Guitplayer, Wheelie, VEW, delky, 1 invisible), 598 guests, and 1 robot.
Topics126,781
Posts1,039,299
Members48,100
Most Online2,175
Jul 21st, 2025
Will a Mercruiser aluminum valve cover work over a roller rocker set-up on my 292ci?? it appears to be slightly taller than my 292 and spare 235 covers. I have just purchased a cover and maybe some day I might be able to afford a roller rocker set up.
anyone know??
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
I don't think it will clear the roller rockers. It's discussed in Santucci's "Inline 6 Power Manual."
1954 GMC De Luxe COE
old string . . . . . new question
will a clifford 6=8 valve cover fit over a set of roller rockers??
Jim & Caroline
I believe the Clifford cover will clear. Two other options are a welded aluminum one from Sissell's Automotive in Covina,CA but it is more of a race looking set-up. There is also a guy making an adaptor to use the early 235 cover on the 292 and that will also clear and adds a nostalgia touch. He advertises in The 12 Port News (club magazine for Inliner's International).
Thanks arpee I thought so but it's nice to confirm. It sure looks tall enough and hard to imagine jack clifford not having it clear.
yes i know about that guy
"wow eek e eek zoweee" it's $300.00 ++ for that adapter !!!
sorry but no
Jim & Caroline
I am fairly certain that none of the aftermarket standard cast aluminum covers will clear roller rocker arms including Mercruiser, Offy and Clifford. Only the adaptor plates and true custom covers will work with rollers. Pretty pricey is right!
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.034s Queries: 13 (0.031s) Memory: 0.6149 MB (Peak: 0.6645 MB) Data Comp: Zlib Server Time: 2025-09-22 22:09:20 UTC
Valid HTML 5 and Valid CSS
