9 members (Charles in CA, dt235sd, jmoore, Jay R, Southerntruck, Flatblu4748, tclederman, 5cameo8, 1 invisible),
72
Mod | | | Forums66 Topics128,128 Posts1,056,683 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49930 09/09/2005 6:58 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | Will a Mercruiser aluminum valve cover work over a roller rocker set-up on my 292ci?? it appears to be slightly taller than my 292 and spare 235 covers. I have just purchased a cover and maybe some day I might be able to afford a roller rocker set up.
anyone know??
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#49931 09/11/2005 7:24 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I don't think it will clear the roller rockers. It's discussed in Santucci's "Inline 6 Power Manual." | | |
#49932 06/12/2006 2:45 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | old string . . . . . new question
will a clifford 6=8 valve cover fit over a set of roller rockers??
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#49933 06/13/2006 7:30 PM | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | I believe the Clifford cover will clear. Two other options are a welded aluminum one from Sissell's Automotive in Covina,CA but it is more of a race looking set-up. There is also a guy making an adaptor to use the early 235 cover on the 292 and that will also clear and adds a nostalgia touch. He advertises in The 12 Port News (club magazine for Inliner's International). | | |
#49934 06/13/2006 11:43 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Thanks arpee I thought so but it's nice to confirm. It sure looks tall enough and hard to imagine jack clifford not having it clear. yes i know about that guy "wow e  zoweee" it's $300.00 ++ for that adapter !!! sorry but no
#49935 06/14/2006 12:07 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I am fairly certain that none of the aftermarket standard cast aluminum covers will clear roller rocker arms including Mercruiser, Offy and Clifford. Only the adaptor plates and true custom covers will work with rollers. Pretty pricey is right! | | |
