4 members (qside, MOTOXFAMILY, 55shaker, dt235sd), 170 guests, and 3 robots.
Topics128,268
Posts1,058,379
Members48,485
#497927 01/26/2009 10:50 PM
this might sound dumb to you guys but i was wondering what kinda milage should i expect out of my 1950 1/2 ton with a 235 3 on the tree and stock rear end i am hopeing to get it done (or at least driveable)by warm weather maybe a daily driver
jeffrey97 #497985 01/27/2009 1:00 AM
8-10
Redryder pix
My Hotrod
joker #498067 01/27/2009 3:36 AM
i usually get around 10 mpg, but I got a V8.
Another quality post.
Real Trucks Rattle
Rusty Rod #498069 01/27/2009 3:44 AM
How are you going to drive it? How well tuned is the motor? What tires are you running?
OldSub #498147 01/27/2009 5:45 AM
I've done as well as twelve with good tires and a light foot. I average about ten.
1953 Chevrolet 3100
rehpotsirhcj #498614 01/28/2009 5:42 AM
That stock rear end ratio must really eat up the gas. I would have expected mid teens easy. My 77 Ford F-100 with a six and three speed gets right around 23 mpg, best I got with it was 26 mpg. Heck my old 68 C-60 dump truck got right around 10-12 mpg empty with a 283 V-8.
That One Guy #498656 01/28/2009 1:42 PM
and I can go a month on a tank of gas
Redryder pix
My Hotrod
joker #498669 01/28/2009 2:46 PM
Is that all? I'm getting about 9-10 mpg in my 1 ton,and it has a 216 with a 5.14 rear.
48 one ton #498703 01/28/2009 4:42 PM
I've got the 5.14 in my truck, with the mighty 216. With a light foot, and not going over 40 mph, I get 16 mpg. BUT, I'm generally driving at about 30 mph in fourth, so the truck is not working. I have noticed when Its raining my mileage drops a bit, what with the vacuum wipers. My 216 is in pretty fine shape though.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #499225 01/30/2009 12:12 AM
I average about 14, but I also have dual carbs on mine. Do keep in mind, todays gas is nowhere near as good as what these trucks were intended to run on.
Bill Burmeister
LONGBOX55 #499369 01/30/2009 4:35 AM
10-13 Smiles per gallon! cool
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
Cliff59 #499431 01/30/2009 6:30 AM
Ol Yeller is giving me almost exactly 10 mpg for the last 3,200 miles. Lots of in town, stop and go. 235 and original 4 on the floor. Not sure about the rear-end, but I know at 45 mph she's a-howlin'.
LONGBOX55 #499480 01/30/2009 12:50 PM
I dont care about the mileage. I just want to drive my truck
jeffrey97 #501813 02/04/2009 6:04 PM
Apprentice
Apprentice
i get from 12 to 15 mpg.never over 50 mph. in my stock 54 w/235 and original rear end.
i am re gearing the rear end and installing a 700r4 trans now so i hope it will improve.
LONGBOX55 #511733 03/01/2009 5:59 AM
I
I Offline
The last time I checked, I was getting over 20 mpg in my 1960 with a 235. It has highway gears and cruses along easy at 55 to 65 mph. I was shocked when I first bought the truck, I expected around 14 mpg. (The day I checked we were driving mainly interstate highways, as an overall average I'm sure it's less than 20 mpg.)
Iron Clad
Iron Clad #512427 03/03/2009 2:48 AM
I put my stock '48 3100 on the road last May, and I've kept accurate records of mileage driven and gas purchased. Over 641.6 miles, I've averaged 14.289 m.p.g.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #513960 03/06/2009 6:52 PM
There are a group of farmers / mechanics in the southeastern part of the country (bryon georgia i think) who are rebuilding older pickup trucks using from old tractors motors that get 40 mpg. i would think the same thinking could done with the old chevy trucks. the website is: www.shadetreeconversions.com. now that would be awesome to have and old chevy truck and not have to stop everytime you took it out to get gas.
1951 Chevy 3800 1-Ton
Howard Knapp
mikec4193 #514249 03/07/2009 6:50 AM
My 55.2 gets about 20 on the highway with a bit of tuning on the carb. These old carbs ran ridiculously rich with stock jetting. I get less than that in normal driving, where i start it on the weekends to run across town for one reason or another. In normal running, cold, choked, less than 5 miles at a time, I probably get about 10 mpg. I don't keep track there.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #514750 03/08/2009 6:01 PM
Did some rough calculations and it looks like the my 59 gets around 10 mpg.
1959 Apache 3200
Apache3200 #515484 03/10/2009 5:42 PM
Does the MPG get much better with the 3.55 rear gear change?
Jason
Helipackmech #517744 03/16/2009 4:03 PM
10 when it had the stock rear .Now around 22-24 with a 3.08 rear. Played with carb a bunch also. 10 is about rite stock.Gas is different around the country so you need to play with timing and valves in different area codes.Tire pressure, gear oils ,wheel alignment all make 1-2mpg gains.
47hotrod #518707 03/19/2009 5:00 AM
Apprentice
Apprentice
Mine got about 10 mpg until I upgraded to a High Energy Ignition (HEI). Now I get about 17 mpg. I have been thinking about replacing the 4.11 with a 3.55. I figure the ratio difference is appx 17% to 18%; so perhaps my mpg would increase that much as well. That would put me at 20 mpg.
1951 Chevy 3100
