3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49805 08/31/2005 10:01 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have a good running Model B Rochester on my 230. I just scored a nice manual choke Carter YF from a Ford 240. Is it worth the swap? I know Carbking hated the Rochester Bs, I have had this one apart several times to get it "right", but it runs really well now & gets about 16 mpg,, but I drive it like an old(er?) man. Brian | | |
#49806 08/31/2005 10:10 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,d leave it alone if it,s working good regardless of my signature. That is respectable gas mileage. I,ve run the model B,s for many years & have had good luck with them. If that Ford carb fit the manifold you would still have to modify the linkage & fuel lines. Than find an air cleaner to fit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#49807 08/31/2005 10:28 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I always tell everyone one else "don't fix it if it ain't broke",, I need someone to tell me that every now & then. The linkage is the same, but I would have to bend up a new fuel line. I have checked my odometer w/GPS & it is right on, I can live w/the mileage just fine,,even @ 2.89 its better than driving that s10 I had,,Brian | | |
#49808 09/16/2005 1:21 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | The Rochester B will function until it warps (which it will). There are two schools of thought here: (1) If it ain't broke, don't fix it. (2) If it ain't broke, fix it until it breaks. And I still detest the Rochester B. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#49809 09/16/2005 1:33 AM | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The fuel mixure will probably be off either too rich or too lean the non-production set up. It takes a lot of dyno work to get the calibration correct under all driving conditions. Nothing like a little high speed detonation to put holes in your pistons from to lean a mixture.
34 & 35 trucks are the greatest
