1 members (baldeagle), 22 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#49805 08/31/2005 10:01 PM
I have a good running Model B Rochester on my 230. I just scored a nice manual choke Carter YF from a Ford 240. Is it worth the swap? I know Carbking hated the Rochester Bs, I have had this one apart several times to get it "right", but it runs really well now & gets about 16 mpg,, but I drive it like an old(er?) man. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#49806 08/31/2005 10:10 PM
Riding in the Passing Lane
I,d leave it alone if it,s working good regardless of my signature. That is respectable gas mileage. I,ve run the model B,s for many years & have had good luck with them. If that Ford carb fit the manifold you would still have to modify the linkage & fuel lines. Than find an air cleaner to fit.
1972 Chevy c10 Cheyenne Super
#49807 08/31/2005 10:28 PM
I always tell everyone one else "don't fix it if it ain't broke",, I need someone to tell me that every now & then. The linkage is the same, but I would have to bend up a new fuel line. I have checked my odometer w/GPS & it is right on, I can live w/the mileage just fine,,even @ 2.89 its better than driving that s10 I had,,Brian
#49808 09/16/2005 1:21 AM
Carburetion specialist
The Rochester B will function until it warps (which it will).
There are two schools of thought here:
(1) If it ain't broke, don't fix it.
(2) If it ain't broke, fix it until it breaks.
And I still detest the Rochester B. wink
Jon.
The Carburetor Shop
#49809 09/16/2005 1:33 AM
The fuel mixure will probably be off either too rich or too lean the non-production set up. It takes a lot of dyno work to get the calibration correct under all driving conditions. Nothing like a little high speed detonation to put holes in your pistons from to lean a mixture.
34 & 35 trucks are the greatest
