1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
How can I determine the rearend ratio in my truck.
Is there a method/trick to find out?
I don't have any documentation, I don't want to open the pumpkin,
I was wondering if I could jack up one wheel and spin the drive shaft........ or something like that.
any help would be greatly appreciated.
thanks all
brian :confused:
"So many trucks, so little time!"
Vehicle list:
down to 2 now.
1 - 1967 Chevy 3/4 ton LWB 4x4
2 - do I dare say it??? a 61 Ford Unibody
Yes, you can do it that way. Make two complete revolutions and count the rotation of the drive shaft. The wheel opposite the wheel you turn should rotate the other direction unless it's a locking differential.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
if I left one wheel on the ground, and it's not a locking differential, would I get double the ratio?
Vehicle list:
down to 2 now.
In other words, with one wheel on the ground (can't turn), turn the other wheel (the one that is jacked up) exactly two revolutions. Your ratio is the number of times the driveshaft turns during two rotations of one wheel.
