7 members (Bill Hanlon, Tom McGrath, Rich'sToys, Jman, Robert Crandall, Steelonsteel, Wally / Montana), 85 guests, and 4 robots.
Topics128,035
Posts1,055,556
#497 11/28/2004 6:22 PM
Need imput! Installing T5 in 66 C10, I have been running cast iron trannys without a rear crossmenber, will the t5 need a rear support?
and what have options have been used for this?
#498 11/28/2004 9:54 PM
There is no need for a transmission support on a 66 with bellhousing mounts.
My Blog
#499 11/28/2004 10:36 PM
Riding in the Passing Lane
I ,ve never done one & i,ve heard opinions both
ways. But I shure would put something under
there. You can buy crossmembers for that or bolt
in a piece of steel with a trans. mount on it. smile
1972 Chevy c10 Cheyenne Super
#500 11/29/2004 4:39 AM
I've been driving my '65 for a few weeks now and it seems pretty good. I do get a little vibration at higher speeds and rpms. Not sure if it's because there's no mount other than bellhousing or if because I'm using a Camaro T5 and the shifter's all the way aft on tail housing.
I do know there were/are 2 factory mounts for the tail housing on Camaro's to steady it. One was a crossmember and the other came straight from the back and attached to a weird bracket/mount. I'm sure the S10's have some sort of mount as well and that got me thinkin' I should come up with one.
The one I've been fabricating runs fore/aft and will mount to the parking brake crossmember and the bellhousing crossmember. I'm hoping this will steady out some of the vibration. I'm a couple days away from completion as I had to change my design slightly. Even if it does nothing for the very minimal vibration, I'll still be happy to have a mounting point. It just seems weird to have that much tranny sticking out and only mounted to bellhousing. Peace of mind I guess.
-David
Kustoms-and-Sleds
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#501 11/29/2004 6:42 AM
I have done about 8 of these conversions some have been on the road for as long as six years all with no crossmember. No problems.
My Blog
#502 11/29/2004 9:53 PM
"MONGO"
"MONGO"
I planned on making a piece to go from the stock mount to the T5 on my 53 and have never gotten around to it, been on the road a couple years now no problems..
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#503 12/02/2004 4:23 AM
Thanks for the input, I was leaning towards not using one, now that I have some input from someone that has done this I will just let it hang like I did my cast iron tranny.
