1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49780 08/31/2005 4:43 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Does anyone out there have a setup like this that is willing to share their knowledge and pictures?
Mike
Mike Barnes 1950 GMC 1-ton pickup
#49781 08/31/2005 11:53 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i am not sure what you are asking but if you want to see pictures of a hook up with a heat plate and tubes to heat the carbs look at my webshots at the bottom of this post. th heat plate came from the stovebolt engine co. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#49782 09/01/2005 7:36 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Thanks Ron - The carbs have a thermostatic spring for the autochoke and need to get heat from the manifold. I'm looking for a way to get the heat to the carbs without cobbling up something ugly and rigging it to my Fenton's.....functionality is primary but the look is a large part of my goal.
#49783 09/01/2005 9:59 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have one reg. rochester and one with an auto choke. i just plug all the holes and used a manual choke on the first carb. i got the second carb free and still havn't replaced it. someday????? ron
#49784 09/02/2005 9:31 PM | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | The HELP line of automotive Products made a choke stove for tubular headers at one time. It was a small tin unit and came with a length of aluminum tubing and woven a heat shield sleeve. It attached to the header with a band clamp. Mounted on the back side it didn't look too bad. It may be worth looking into, if they still make it. | | |
#49785 09/10/2005 12:43 AM | Joined: Jul 2002 Posts: 20 Junior Member | | Junior Member Joined: Jul 2002 Posts: 20 | I have a 235 out of a 59 chev car. It has a band around the exhaust manifold with a tube going to the carb. This is a factory set up, so you might find one at a swap meet. | | |
