2 members (55shaker, Hotrod Lincoln), 137 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
Does anyone out there have a setup like this that is willing to share their knowledge and pictures?
Mike
Mike Barnes
1950 GMC 1-ton pickup
i am not sure what you are asking but if you want to see pictures of a hook up with a heat plate and tubes to heat the carbs look at my webshots at the bottom of this post. th heat plate came from the stovebolt engine co. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Thanks Ron -
The carbs have a thermostatic spring for the autochoke and need to get heat from the manifold. I'm looking for a way to get the heat to the carbs without cobbling up something ugly and rigging it to my Fenton's.....functionality is primary but the look is a large part of my goal. frown
Mike Barnes
i have one reg. rochester and one with an auto choke. i just plug all the holes and used a manual choke on the first carb. i got the second carb free and still havn't replaced it. someday????? ron
2017 Buick Encore
See more pix
The HELP line of automotive Products made a choke stove for tubular headers at one time. It was a small tin unit and came with a length of aluminum tubing and woven a heat shield sleeve. It attached to the header with a band clamp. Mounted on the back side it didn't look too bad. It may be worth looking into, if they still make it.
Junior Member
Junior Member
I have a 235 out of a 59 chev car. It has a band around the exhaust manifold with a tube going to the carb. This is a factory set up, so you might find one at a swap meet.
