2 members (Hotrod Lincoln, homer52), 93 guests, and 0 robots.
Topics128,049
Posts1,055,638
#496968 01/24/2009 4:10 AM
1 Offline
I'm a bit confused with this. According to my manuals - my 64 GMC 305e V6 with sm420 tranny should use an 11" clutch disk. Most of the online parts people (Rock Auto, etc.) suggest a clutch kit which includes a 12" disk. Will this work? Does anyone have an experience with this either good or bad? Advice appreciated.
Thanks.
1Oldschoolguy #497179 01/24/2009 10:01 PM
Riding in the Passing Lane
There are a lot of variations in clutches. Its best to pull the old one out & measure it. The chev truck flywheel will take either 11 or 12 in. clutches. Its been about 40 years since ive been in a V6 Jimmy but if I remember right the clutch was recessed in the flywheel. It will have to have the exact replacement. If I had a choice between the 11 &12 I would use the 11 in. unless I was doing some heavy hauling or had a driver that was hard on clutches.
1972 Chevy c10 Cheyenne Super
Call up your local brake shop and get a quote on the cost of rebuilding both. Even your local Napa can send them off, just make sure to get a qoute first. I had the pressure plate rebuilt and the clutch relined for about $125 total. That was with my 11" Gmc clutch and 9 bolt pressure plate in my COE.
Definately worth a call around.
My 1953 Chevrolet
1947.1 Gallery
