| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Need imput! Installing T5 in 66 C10, I have been running cast iron trannys without a rear crossmenber, will the t5 need a rear support? and what have options have been used for this? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is no need for a transmission support on a 66 with bellhousing mounts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I ,ve never done one & i,ve heard opinions both ways. But I shure would put something under there. You can buy crossmembers for that or bolt in a piece of steel with a trans. mount on it.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I've been driving my '65 for a few weeks now and it seems pretty good. I do get a little vibration at higher speeds and rpms. Not sure if it's because there's no mount other than bellhousing or if because I'm using a Camaro T5 and the shifter's all the way aft on tail housing. I do know there were/are 2 factory mounts for the tail housing on Camaro's to steady it. One was a crossmember and the other came straight from the back and attached to a weird bracket/mount. I'm sure the S10's have some sort of mount as well and that got me thinkin' I should come up with one. The one I've been fabricating runs fore/aft and will mount to the parking brake crossmember and the bellhousing crossmember. I'm hoping this will steady out some of the vibration. I'm a couple days away from completion as I had to change my design slightly. Even if it does nothing for the very minimal vibration, I'll still be happy to have a mounting point. It just seems weird to have that much tranny sticking out and only mounted to bellhousing. Peace of mind I guess. -David Kustoms-and-Sleds | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have done about 8 of these conversions some have been on the road for as long as six years all with no crossmember. No problems.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | I planned on making a piece to go from the stock mount to the T5 on my 53 and have never gotten around to it, been on the road a couple years now no problems.. MONGO | | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Thanks for the input, I was leaning towards not using one, now that I have some input from someone that has done this I will just let it hang like I did my cast iron tranny. | | |
