7 members (Goach2, Dave1234, IHPWR, Hotrod Lincoln, TUTS 59, Peggy M, 1 invisible), 73 guests, and 4 robots.
Topics128,206
Posts1,057,440
Members48,471
#495990 01/21/2009 9:59 PM
I have a 52 chev 2ton dump single ram does anybody have info on them (manuel or picks of mechanical diagram
eliminatethis #496151 01/22/2009 3:31 AM
Try this Tech Tip:
http://www.stovebolt.com/techtips/hoist.htm
This is not guaranteeing that its one of these manufacturers, as there are endless possibilities. Back in the day, anything was done to make what you needed to get the job done. In my case, or, in the truck I'm eying up's case (long story), the ram/pump was pulled from a junkyard, taken to a welding shop, and custom fabricated to make a hoist/dump body for the truck (IE, the pump and ram could have been 20-30 years old in the 1950s, who knows). Anything is possible, but that is a start.
No 'bolt yet, but if you'd like to help me out with that, send me a message! Or check out my wanted add in the swap meet.
morton #496519 01/22/2009 10:12 PM
thanks looks close but go and your right it is most likely a take off
eliminatethis #497469 01/25/2009 7:09 PM
yep its pto and my brothers is a 41 chevy dumper not a grain [box] truck , and has a PTO n cable to put in / and release, method
care to chat write back
mickster #497470 01/25/2009 7:19 PM
Eliminatethis: I may be able to help you with your hoist questions if you send me a photo of it. I am the one who wrote the TechTip and have some experience with them.
Mickster: I don't get your statement (?) Can you rephrase it?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #499045 01/29/2009 3:27 PM
53MONEYPIT I will try to get a pics this afternoon. the only name is on the dump valve I believe it says Harsh Hoist but may only apply to the pump the ram is huge with two hoses off it one at the bottem one at the top each goes into a odd manifold that attaches to the ram and looks like it ports into the cylider at two places in each manifold the top goes to a vent cap and the bottem goes to the pump the pump is a one way only gravity return (or down) the ram is mounted on the frame and pushes on a pivot arm that has two solid rams going back to the bed and the bed has pivot points at the very rear
eliminatethis #499237 01/30/2009 12:42 AM
Your pump has been changed to a much later unit. Is it inside a reservoir with the driveshaft going directly to the pump input shaft? If so then you have a piston pump that is capable of a LOT more pressure than your old piston cylinder will withstand. Harsh likely came into being after your hoist was retired. Anyway please send the pictures.
Dave
I have found out it is not a harsh hoist heil hoists nolonger do dumps but sent me to TBE-duraclass wich used to be Heil dump hoists and waiting for a answer any help would be great
eliminatethis ; Not to be a stick in the mud but Please use a off site photo hosting site to put your photo's on then link them to this site . Please read the rules for posting photos on site as shown on the left hand side of this page. Let's help keep site costs down - Thanks . ED H
sorry (stick in the mud) had one of my employees post it for me I will not do it again
eliminatethis #501939 02/04/2009 11:28 PM
I've got a 51 Chevy 2 Ton 6100 series that needs some body parts. Looking for inner and outer cowls for both sides at firewall. Mine are pretty much gone. Help
beacon #502033 02/05/2009 3:37 AM
beacon - you might want to post this in the - "truck parts wanted" - forum . You will get more people viewing your needs. ED H
Your pump appears to be a Williams 4 piston model and the hoist is definately low pressure. Tie rod cylinders don't take a lot of pressure but you pump will develope up to 3000 psi. There is a relief valve on the pump that should not be set above 1000-1200 psi. The pump will never exceed what is required to make the piston move but with a lot of resistance (work) for it to overcome your pump could blow it to pieces so it is a matter of safety that the relief valve be set correctly. It may be either adjustable or non-adjustable.
Your directional valve appears to be a correct 3 way valve. Check your hoses too for condition and pressure type.
Incidentally, those two "solid rams going back to the bed" are called the lift arms. When hoisting and in the full up position they along with the pivot arms form a triangle which provides the mechanical advantage. It is a quite old hoist so be careful when using it, it may have stress cracks, etc.
Dave
Sounds great. Hey maybe you can help a new green member on a question about my ? 1953! 2 Ton 6100 (16,000GVW). What does COE stand for on ID of the truck. It states that it is a 53, 6100, 2 ton, dump COE
beacon #502308 02/05/2009 11:43 PM
Not sure where you're getting the COE, it usually means Cab Over Engine which is a 5000 model not a 6100. 6100 is a 2 ton with a 137 inch wheel base. Take a look at the COEs in the Gallery.
Larry
Larry Hayes
Charlottesville, VA
48 3600 Flat Bed
49 6400 Grain Dump
48 Allis Chalmers G
Harsh hoists are still built in Eaton, Colorado. Their phone is 970-454-2291. Used them for years and they're good equipment.
51 Chevrolet Canopy Express
02 K25 Duramax Crew Cab
