11 members (Otto Skorzeny, Southerntruck, D B Cooper, klhansen, Peggy M, Jims46, Hawkman, manymiles, MikeE, joe apple, 1 invisible), 100 guests, and 2 robots.
Topics128,049
Posts1,055,675
#493002 01/14/2009 2:56 AM
I have a question about firewall grommets. I have all of the necessary grommets for my truck; however, several of them the cable that goes through them the end is much larger than the hole in the grommet. Any tips on how I go about getting them on without cutting them? I tried cutting them but they just don't seem to want to stay.
If you cut them is there something out there that can be used to glue or fuse the cut ends back together?
I'm sure that someone out here has solved this one. How did you do it?
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
You can glue them back together with rubber or contact cement. The stuff that you get for rubber membrane roof repair or tube tire patches works great. You only get one shot at it, though, its permanent.
Paint & Body Shop moderator
Super glue will work too
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
why not just put a couple of wires thru at a time until all wires are thru/inside.
there is nothing to say you have to put thru all wires at one time
unless I don't get it. ohwell dang
but I wouldn't cut the grommet myself....................
Jim & Caroline
Put wires or cables thru first then install grommet.Or if needed use heat gun to soften grommet without melting!
interesting thoughts. Being that I have already cut them, i'll try the glue once it warms up a bit. The problematic ones it does not appear that the grommet would stretch enough to get them through. Have also not tried the heating method.
Thanks for the replies.
Tim
Tim Sheridan
Ex Hall Monitor
Ex Hall Monitor
Unless you get a lot of splash under the hood you probably don't even need to glue them. Just put the cut at the bottom where it isn't as obvious.
Tiny #496630 01/23/2009 3:38 AM
That's whatI was originally thinking but they dont seem to want to stay in. I hope the glue thing works. I'll post once I know (in the spring)
Tim Sheridan
