1 members (Opelika Tom),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I searched for info, but either there isn't any, or I don't know how to search.
Is there a dual master cylinder that will bolt in place in a 59 Apache? If not, is it a lot of work to mount one?
Thanks.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | You can buy the power boster brake system and bolts in the stock location.no limit or classic truck parts have them.
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | I used one from a85 impala car.don't forget the propourition valve.it's a no brainer.thebone yards are full of them
dan-pa
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | You would need an adapter bracket to bolt in a more modern dual res master cylinder in your truck. Most of the usual vendors sell them. There is a good tech tip on this. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | just use the rod from the hanging brake pedal the one you take the master cyclinder off.You will have too drill new mounting holes in the firewall for the master cyclinder.no need to .buy a adapter.just drill new holes for mounting.things will line up pretty close.never knew they made a adapter for that.just use common scents
dan-pa
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | There is no hanging pedal on a '59. The mc is under the floor, so you need a bracket to mount a dual res. master cylinder in the stock location whether you buy one or fab one yourself. | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 |
