7 members (2-Ton, MRMEROTH11, Gdads51, JW51, Shaffer's1950, Southerntruck, 1 invisible), 118 guests, and 1 robot.
Topics128,132
Posts1,056,378
Members48,441
#495336 01/20/2009 2:29 AM
I searched for info, but either there isn't any, or I don't know how to search.
Is there a dual master cylinder that will bolt in place in a 59 Apache? If not, is it a lot of work to mount one?
Thanks.
"Happiness equals reality minus expectations" - Tom Magliozzi
You can buy the power boster brake system and bolts in the stock location.no limit or classic truck parts have them.
1955 GMC Big Window
1957 Chevy 1.5-Ton
1959 Chevy Short Fleetside
Plus lots more ...I LOVE THESE TRUCKS!!!
I used one from a85 impala car.don't forget the propourition valve.it's a no brainer.thebone yards are full of them
dan-pa
You would need an adapter bracket to bolt in a more modern dual res master cylinder in your truck. Most of the usual vendors sell them. There is a good tech tip on this.
Steve
'49 3800
'52 3600
'57 3100
just use the rod from the hanging brake pedal the one you take the master cyclinder off.You will have too drill new mounting holes in the firewall for the master cyclinder.no need to .buy a adapter.just drill new holes for mounting.things will line up pretty close.never knew they made a adapter for that.just use common scents
dan-pa
There is no hanging pedal on a '59. The mc is under the floor, so you need a bracket to mount a dual res. master cylinder in the stock location whether you buy one or fab one yourself.
Steve
'49 3800
'52 3600
'57 3100
Thanks for those tips.
