0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | I would like to get rid of the points in the distributer. I have seen some good and some bad about Pertonix. Is the only other option to buy the $355.00 HEI distributer from the guy on e-bay? He says he is the only one that has the correct distrubuter that will drive the oil pump. I find this hard to believe. Has anybody used anything else? I need some suggestion, or should I just get Pertronix?
Thanks, Rcimp
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
| | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Check Tom Langdon for the HEI distributor. I prefer it over the Pertronix because if you have a part failure and you're on the road, you can get replacement parts for the HEI distributor. Where will you find a replacement Pertronix. The alternative to a failed Pertronix unit is to stick your old points pieces back in.
If I remember correctly, the Landon distributor is a S-10 unit. I've already replaced one part in mine without any problems. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | www.stoveboltengineco.com see if there isn't a less expensive HEI there that will suit your needs. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I have been using Pertronix on my MGA for about 10 years with out a problem. I was concerned about a failure so I bought a spare that has been in the tool box in the trunk for 10 years. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I bought a 12v Pertronix unit for $65 about 10 years ago and a 6v Pertronix unit about 5 years ago. I also bought a complete rebuilt distributor for $69 as a back-up "spare" (about 5 years ago). The distributor came with points, condenser, and cap - I have added a spare vacuum-advance unit.
I have been carrying the rebuilt distributor as a Pertronix back-up when I go on a long trip with either truck. Never had to use the backup but it's nice to know I have it.
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i got an hei out of a 250 and mod. it . the instructions are in the tech tips. i think i ended up with just over 100 bucks in mine with a new module and new wires. i tried the pertronics im my old tractors they dont last.
| | | | | Joined: Sep 2008 Posts: 84 New Guy | | New Guy Joined: Sep 2008 Posts: 84 | Same here as philipt. I also puled my HEi out of a '79 250. Mods are pretty easy to do. | | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | Thanks for the tips guys, I decided to purchase Langdons mini HEI. I am not that good at modifying so I decided to let the professional do it. I can't wait to get it installed.
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | go ahead and have tom throw one of his holly weber kits it the box and your engine will run better than when new. i love mine. philip | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Langdon's HEI (not the mini) at $95 is a real bargain and it includes the GM coil. Will make your engine fire first time every time. | | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | I received Langdon's Mini-HEI. I installed it and the so truck starts and idles much better. I have to come up with a way to mount the square coil he sent. I think I will use some C-channel and mount it in the original location of the old coil unless someone has a better idea.
