0 members (),
64
Mod | | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Im looking to install a T5 in my 52 (behind a 54 235) and was wondering if there is any difference in using a T5 out of a 97 f-body car with the 3.8 compared to earlier versions. I know it uses a electronic speedometer setup, which is fine with me. Anything else? | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Oh and im going with a f-body transmission so I don't need to modify the input shaft. My truck has bucket seats so Im fine with the shifter being farther back than stock. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The later T5's have the Ford mounting pattern and wont do you much good, however I have heard that they have the room to drill the GM pattern on the lower tabs.
| | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | thanks Scott, good thing to know. I was at the local yard two weeks ago trying to remove a t5 out of a 98 camaro. I had everything unbolted and unhooked but it would not budge. Couldn't get it off the bell housing. The throwout bearing must have been frozen onto the transmission. I ended up leaving it because I didn't have a short 18mm to remove the bell housing from the engine. Good thing to know that I didn't get it out.
Thanks Again! | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | so up to what year can I use? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | up to 92 on F-bodies, up to 94 on S-10's. The 94 S-10s are rumored to have the Ford Pattern as well. However Like I stated, the lower ears may have enough room to re-drill the 2 holes for the GM pattern. This is getting into the area of knowledge by others area and not first hand.
