8 members (HandyAndy, Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series), 72 guests, and 7 robots.
Topics128,022
Posts1,055,352
Members48,420
#494388 01/17/2009 4:08 PM
Im looking to install a T5 in my 52 (behind a 54 235) and was wondering if there is any difference in using a T5 out of a 97 f-body car with the 3.8 compared to earlier versions. I know it uses a electronic speedometer setup, which is fine with me. Anything else?
drummin52 #494391 01/17/2009 4:10 PM
Oh and im going with a f-body transmission so I don't need to modify the input shaft. My truck has bucket seats so Im fine with the shifter being farther back than stock.
drummin52 #494420 01/17/2009 5:47 PM
The later T5's have the Ford mounting pattern and wont do you much good, however I have heard that they have the room to drill the GM pattern on the lower tabs.
Scott Danforth #494511 01/17/2009 11:09 PM
thanks Scott, good thing to know. I was at the local yard two weeks ago trying to remove a t5 out of a 98 camaro. I had everything unbolted and unhooked but it would not budge. Couldn't get it off the bell housing. The throwout bearing must have been frozen onto the transmission. I ended up leaving it because I didn't have a short 18mm to remove the bell housing from the engine. Good thing to know that I didn't get it out.
Thanks Again!
drummin52 #494512 01/17/2009 11:11 PM
so up to what year can I use?
drummin52 #494963 01/19/2009 1:54 AM
up to 92 on F-bodies, up to 94 on S-10's. The 94 S-10s are rumored to have the Ford Pattern as well. However Like I stated, the lower ears may have enough room to re-drill the 2 holes for the GM pattern. This is getting into the area of knowledge by others area and not first hand.
