| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 19 Apprentice | | Apprentice Joined: Aug 2008 Posts: 19 | When I bought my '58 Apache the dipstick was missing. Tube is still there I just need the stick. Is there anywhere that I can find a replacement? I've looked at LMC and Carters and a couple other places but none seem to have them. Maybe someone out there has a spare that I can buy from them?? The engine is a 235.
Any info would be appreciated. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | On my GMC 248 I used a SBC dipstick and ended up cutting about 6-8" off it. Fits fine. | | | | | Joined: Aug 2008 Posts: 19 Apprentice | | Apprentice Joined: Aug 2008 Posts: 19 | I'm sure it would fit ok, but how on Earth would I know where the oil level should be without the markings? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Change the oil. Leave the filter alone so it's full of oil. Add the recommended amount of oil minus one quart. Run the engine for 30 seconds & mark the level on the dipstick. That's your one quart low mark. Add one quart & mark the full level. The edge of a file will work well for making the marks.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | As Tiny says, its easy enough to scribe a line on the dipstick.
I believe there were different heights on the tubes that stick out of the block, (at least on GMCs Im pretty sure) so even having a replacement from another 235 might not help. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Post in the truck parts wanted forum,I'm sure somebody will have one. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
