| | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49428 08/23/2005 7:12 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I've had it with my Rochester B models on a Offy intake. Look very cool but won't run worth a darn. I would like to fit up either a Offy intake to a small (500cfm) Edelbrock 4 barrel carb or retrofit my old Offy intake (two each one barrels). I've read several posts on changing the Rochesters to other kinds/types. What newer/modern types of 1 or 2 barrel carbs with fit up to this my old setup? If I need adapter plates where do I get? I'm not trying to melt tires, just run the roads often in hot weather. Your comments please. Thanks in advance.
#49429 08/23/2005 8:19 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | If you decide on the four-barrel route I'd suggest you take a look at the Holley 390 CFM unit. It would be better than the Edelbrock for this application IMO.
I have the dual Holley-Weber 2 bbl and would not do it again. A single four would be a lot less trouble I think. The 2 bbl adaptors are available form Langdons. | | |
#49430 08/23/2005 11:28 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Call up Tom Langdon at www.stoveboltengineco.com . He will talk your leg off, but will have a lot of good advice on the 4 barrel choices. He can also tell you about the Holley-Weber rebuilds he sells, they are a progressive 2 bbl, and can be used on your Offy intake with adapters. Here's what they look like http://www.myoldtruck.com/gallery/files/2/3/8/Engineleft.jpg The Rochester one barrel is a poor carb for duals. For some good advice on dual ones, search this forum for posts by carbking. He restores antique carbs.
Fred 52 3600 69 C-10
#49431 08/24/2005 2:07 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Holley makes a 450 CFM carb for applications like this but they are kinda pricey | | |
#49432 08/24/2005 11:05 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I've got the Offy with the Edelbrock 1404 and it works well. Runs great, easy tuning. I plumbed water heat (make sure to JB weld the plugs in the manifold) and I never any driveability problems in 4 season driving. Got the setup off Ebay for less than the price of a new carb. | | |
#49433 08/24/2005 4:59 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I run an Offy manifold with 625 Carter AFB (about the same thing as an Edelbrock 1406) on my 292 and I love it. You'd have to beat me senseless before I went back to the Monojet.
I don't use water heat. But the electric choke is a wondrous thing, especially in the climate I live in where the temperatures fluctuate wildly. It's nice to be able to get in the truck, twist the key and drive off without having to warm it up (within reason) and drive it while it's cold without a lean backfire. I use a throttle pedal and bracket from a 74 C10 and a throttle cable for a 73 Monte Carlo. Works great. | | |
