Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (baldeagle, 2 invisible), 79 guests, and 1 robot.
Topics128,285
Posts1,058,535
Members48,490
#49400 08/22/2005 10:39 PM
Junior Member
Junior Member
I hear of people using the t-5 from s-10 and blazers in line- engines i am curious to see wheather it would be compatible with the 305 v6. By the way i have 4.56 posi rear with the 3 speed tree shifter. Thanks for the help guys
Keep Truckin
Sounds like you like to go slow and tow a lot w/ the 4.56:1 The OD in the T5 would help speed things up for ya. Can't help ya w/ the V6 but it should bolt up to any chevy bell housing.
gooday
jim
Jim & Caroline
V
V Offline
it will be compatible for a while.the 305 V6 makes a lot more torque than engine offered in an s-10
get a t-5 out of a camaro, the camaro used them. the only problem is where the gearshift is located, on the camaro tailshaft to far back. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
