6 members (Gdads51, Ponchogl, Otto Skorzeny, Wayne67vert, BillyDon, carbking), 126 guests, and 4 robots.
Topics128,272
Posts1,058,316
Members48,485
#492182 01/11/2009 10:13 PM
Recetly upgraded to a 383 stroker with a 400 turbo long-tail. the problem i have is that going down the road the speedo is buried and i am only doing 10-15mph. is their a solution to my problem???????????
Jacks1952 #492184 01/11/2009 10:16 PM
The motor mounts I am currently running are the 50's style that bolt to the front of the engine. It is a high horse/torque motor and I want to install the mounts the bolt to the side of the block for extra support. Does anyone have a recomendation or prefferance to motor mounts?
Jacks1952 #492378 01/12/2009 7:56 AM
I would think your Speedo ratio is WAY off compared to your tranny drive gear...Mine 350/350th...is off bought 12 mph and I need to adjust the teeth on the tranny drive gear, But burryin the speedo at 10 to 15 MPH seems like something is way outta wack and changin the tranny gear will not help.
I bet ya need to replace the speedo.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #492974 01/14/2009 1:36 AM
I am not sure as far as how fast we were going or exactly what the speedo said, my wife was driving. But i do know that it did chirp and squeak as the needle moved. Also, what trany speedo gear should i change to to be somewhat acurate with the original speedo?
Jacks1952 #493053 01/14/2009 4:28 AM
Jack, you need to determine the rear end gear ratio, then change the drive gear in the tailshaft( were you connect the speedometer cable) a gm dealer or a speedometer shop can help with the right gear. It's easy to change, but it sounds like something else is wrong.
Tommy
59 apache 1/2t
261 short stepside
Tommy #493615 01/15/2009 6:57 PM
Maybe check & see if the cable is sticking or hanging up.
Making any noise?
Cajunbowtie
cajunbowtie #493706 01/15/2009 10:54 PM
My speedo would bury itself when I first started driving my truck. It had been sitting for almost 8 years.
I thought it might have been the cable or the new transmission I put in with overdrive. What I found was the mechanism/speedo in the dash was gummed up. I took the instrumentation cluster out of the dash, took it a part and cleaned/oiled it. When it was back together and in the truck it all worked. Now my speedo works fine.
Are you sure this is not your problem?
Dennis
The speedo does make a chip/squeaking noise, the truck had been sitting for a number of years, as far as matching the gear ratio of the rear (which is a ford 9 inch) i think the gear ratio was 3.50,it came out of a 70's f-100. does anyone have a recomendation or a part number i can referance?
