2 members (Hotrod Lincoln, Millenimech), 76 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#493322 01/15/2009 12:20 AM
Question: smile
I have a 235 with a mechanical fuel pump on it. If it is working properly, should it hold fuel at the carb after shutting engine off? Mine is very hard to start after sitting for a day or so, because it has to pump fuel back to the carb. Once the fuel is to the carb she fires right up.
there should be enough gas in the float bowl to start it the next 3-4days.
and by the time you crank some there is more gas.
pull the gas line off the carb
turn over engine and you should see gas thru in tubing.
if not or very low levels, check fuel filter or clogged fuel line or pump diaphram
squirt carb throttle and see/hear gas inside carb. or check for stuck float, needle & seat for flow or clogged orfice
Jim & Caroline
After sitting for a day I usually dont have a problem. But if I let it sit for 2-3 days, the gas has usually evaporated out of the carb and it takes a little longer.
By the way, happy birthday. smile
My 1953 Chevrolet
1947.1 Gallery
waveHa,thanks guys for the feed back. I was just curious because it seems to have to crank alot after sitting. I just got this thing going and it runs out great. After putting a filter before and after the pump the fuel seems to only be present in the filter before the pump after sitting for a day. Thanks for the B-Day wishes. headscratch
Are you choking it when you start it up? Gotta' ask.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Woody,
wave
Yes, choke is working. Great looking door art, and your web site is great. Good job!!!
After a few days the highly combustible part of the gasoline has evaporated, leaving the less potent part still in the cab. It doesn't ignite as easily. If your ignition system isn't operating at 100%, you can get hard starting. You may want to check everything there. Don
One thing often missed, is the "primary coil wiring", low voltage. The wire connecting to the "plus" side of the coil and the small wire going from the coil to the distributor must be in great condition to provide full current through the coil. If wire strands are broken at these terminal connections of the distributor and coil, the ignition system will not work effectively. Don
Ex Hall Monitor
Ex Hall Monitor
Kevin, my 38 has to crank a bit when she sits for a while. I suppose it could be an issue of a bad valve in the fuel pump allowing gas to slowly siphon back into the tank. The next time she sits for a week or so I'll need to check the bowl on the fuel pump & see if it's full of fuel or not.
Thank You Guys, thumbs_up
I will check those mentioned, and keep tou posted.
