6 members (gswbbc, tonyt, Otto Skorzeny, baldeagle, 55shaker, DES57), 89 guests, and 3 robots.
Topics128,040
Posts1,055,474
Members48,424
#493321 01/15/2009 12:17 AM
I have an 87 350 gmc with throtle body, I want to switch to a carberated. Does any one make an intake for this switch??
derry #493349 01/15/2009 1:56 AM
Edlebrock probably makes one
Edlebrock, Holley, Wiend, Summit, GM Performance, etc.
However why change from TBI to carb? The driveability alone would make one want to keep it.
As I understand it to keep it TBI would involve changing tanks to get electronic fuel pump. Is this difficult? Is this true? I am using parts off an S 10 pickup for the steering rearend etc. Would the tank be needed also.
derry #493486 01/15/2009 12:19 PM
the TBI motor needs 15 psi (1 Bar). There are external fuel pumps on the market for cheep. Holley makes them for their Pro-Jection line. Carter makes them as well.
You will also need a return line to the tank which is not a big deal. I added a larger supply and a return to my '48 tank when I had it out. You could also simply make a mini sump with the in-line tank from the S-10.
I also highly recommend Stealth Conversions for information and parts. http://jagsthatrun.com/
here is another link that you may find usefull http://www.automedia.com/TBI_Fuel_Injection_Conversion/pht20001001fi/1
