2 members (klhansen, 2-Ton),
85
Mod | | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 49 New Guy | | New Guy Joined: Nov 2008 Posts: 49 | I have an 87 350 gmc with throtle body, I want to switch to a carberated. Does any one make an intake for this switch?? | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Edlebrock probably makes one | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Edlebrock, Holley, Wiend, Summit, GM Performance, etc.
However why change from TBI to carb? The driveability alone would make one want to keep it.
| | | | | Joined: Nov 2008 Posts: 49 New Guy | | New Guy Joined: Nov 2008 Posts: 49 | As I understand it to keep it TBI would involve changing tanks to get electronic fuel pump. Is this difficult? Is this true? I am using parts off an S 10 pickup for the steering rearend etc. Would the tank be needed also. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | the TBI motor needs 15 psi (1 Bar). There are external fuel pumps on the market for cheep. Holley makes them for their Pro-Jection line. Carter makes them as well. You will also need a return line to the tank which is not a big deal. I added a larger supply and a return to my '48 tank when I had it out. You could also simply make a mini sump with the in-line tank from the S-10. I also highly recommend Stealth Conversions for information and parts. http://jagsthatrun.com/here is another link that you may find usefull http://www.automedia.com/TBI_Fuel_Injection_Conversion/pht20001001fi/1
