1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3 Junior Member | | Junior Member Joined: Mar 2004 Posts: 3 | I have an 1988 Gmc p/u. when i turn the ignition on the fuel pump is puming gas up to the injectors, but they aren't shooting gas into the intake before i turn it over. what could be causing this? | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | no idea, but the guys and gals at http://www.fullsizechevy.com could probably help you figure it out. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The injectors trigger from the "crank" signal from the ignition module. Is it getting spark, and do the injectors spray during cranking? If so, it's working like it's supposed to. If it was squirting gas before you crank the engine it would flood. Try a 12 volt test light, to the "tach" terminal of the distributor cap. It should flash rapidly when the engine is cranked. If not, you've either got a bad module or pickup coil in the distributor. In that case, there will also be no spark, along with no spray. Jerry
#4934 03/12/2004 12:10 AM | Joined: Mar 2004 Posts: 3 Junior Member | | Junior Member Joined: Mar 2004 Posts: 3 | yes it does spray gas into the engine and it does start (after cranking it a while) i juss thought that i remember it spraying a gas for three seconds and then kicking off (like it was a choke) thank you for the help though.
sam | | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | If it cranks over and always eventually starts, I'd check the fuel pump relay on the firewall. If this relay fails, the Control Module senses the fault and provides +12 volts from another source (I believe from the oil pressure sensor, once oil pressure is detected). | | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | Some gm v8's have a ninth injector that sprays a constant spray of fuel into the manifold only while starting. Maybe it's screwed up?
The shortest distance between two points is probably under construction
