| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I have a question about firewall grommets. I have all of the necessary grommets for my truck; however, several of them the cable that goes through them the end is much larger than the hole in the grommet. Any tips on how I go about getting them on without cutting them? I tried cutting them but they just don't seem to want to stay.
If you cut them is there something out there that can be used to glue or fuse the cut ends back together?
I'm sure that someone out here has solved this one. How did you do it?
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can glue them back together with rubber or contact cement. The stuff that you get for rubber membrane roof repair or tube tire patches works great. You only get one shot at it, though, its permanent.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | why not just put a couple of wires thru at a time until all wires are thru/inside. there is nothing to say you have to put thru all wires at one time unless I don't get it. but I wouldn't cut the grommet myself....................
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 29 | Put wires or cables thru first then install grommet.Or if needed use heat gun to soften grommet without melting! | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | interesting thoughts. Being that I have already cut them, i'll try the glue once it warms up a bit. The problematic ones it does not appear that the grommet would stretch enough to get them through. Have also not tried the heating method.
Thanks for the replies.
Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Unless you get a lot of splash under the hood you probably don't even need to glue them. Just put the cut at the bottom where it isn't as obvious.
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | That's whatI was originally thinking but they dont seem to want to stay in. I hope the glue thing works. I'll post once I know (in the spring)
