0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#492146 01/11/2009 7:39 PM
Well I just found out why I was having so much trouble getting the starter to run reliably... I pulled the cover off of the end of the starter to find a pile of rust, bushings, and bushing springs fall out. I have no idea how water got trapped in there but the starter is in dire need of a rebuild or possibly a replacement. Is there any place that sells a rebuild kit for a 12v foot-stomp starter (in a 55 2nd series with a 235ci engine)? I am on a rather tight budget with the truck and I'd rather not spend $130 on a new starter or $50-70 for someone else to rebuild the starter when I could do it myself. Worst comes to worst I may just look around for a old starter out of the junkyard...
Neil
1955 Chevy 3200
jdl Offline
Check your flaps or Napa, I know they have at least a little of what you need to rebuild your starter.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Check out www.classicgenerator.com You'll find it under the Stovebolt "Links" under electrical. I bought a starter rebuild kit from them, seems ok but I haven't had time to install it yet. The small package of necessary parts were delivered in a matter of days.
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Make sure that you clean up the back plate. Sand blasting is the best. It is quite common for rusty starters to lose contact at the brush holders.
