4 members (Hotrod Lincoln, FishinToms53, Bill Hanlon, Charles in CA), 71 guests, and 3 robots.
Topics128,087
Posts1,056,000
Members48,430
#49035 08/14/2005 6:59 PM
Junior Member
Junior Member
As you could tell from my "Pull the engine?" post, I'm new at this. This story will make you cringe as well. I was removing the rocker arm assembly, and it came apart, scattering half the parts around the garage. After picking up everything I could find, I'm missing both of the thin washers (bushings? shims?) that go on the rocker arm shaft next to the oil connector. Does anyone out there have these, or know where I can get them? I'm supposed to put the engine back together over Labor Day weekend, and I'm sunk without these.
Thanks again!
Put a post in the parts wanted section. Hopefully someone will help you out. Cecil......
