2 members (Don88, Nick in Manitou), 111 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
is it easier to fix the rusty floor or replace the cab and fix the dents n things on a different cab 63 c60 apache{http://s427.photobucket.com/albums/pp359/oldwestrnwear/?action=view&current=scan0054.jpg}
1963 Chevy C60 Apache Dump Truck
Stovebolt Gallery Page
Photobucket pictures
Apprentice
Apprentice
I'm trying to decide the same thing on my Dump truck project(s)
I've got a 66 GM C50 Dump with a 5 yard bed, new tires and brakes, runs and drives but needs wiring etc.. and it leaks like the Exxon Valdez! The cab on this one is in really bad shape.
Then I've got a 66 GMC 4000 Dump, with a 3-4 yard asphalt dump bed, doesn't run, but - the cab is lightyears better than the GM
On my projects I will probably decide based on the amount, if any, of structural rust ~ ie. cab re-inforcement bracing and the cab mounting points.
If the structural areas of the cab are good - I believe most of the sheet metal and patches can be purchased new-reproduction
IF the stuctural areas are bad then I'm probably going to sell them off rather than do a cab swap as by myself, that's a nearly impossible task to do without a couple of gantry's or a forklift.
If the biggest issue is the floor then it isn't such as huge task. I've seen and done some really badly rusted car floors and they went OK. Easier than switching the cab IMO. Each case is different obviously.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I will tell you how we handle things here in the shop. If we took in a truck like this. First we would go threw it and write down the problem areas Like the right door for example. you say the floor but, It is hard to tell as there is no pictures. etc,etc.
Then What we would do is look around for the replacement parts. If the Floor is bad. Let see if we can locate a good cab to work with.
If you find one. what is the price?
Here is the big question............ Are we doing a frame off? If so, then everything in the cab will come out anyway. so, If I find a cab that would cost less than what I will pay a guy to repair. well, It would make sense to replace the cab.
as for the door. You can fix that one or get another one.
So, If the replacement parts are cheeper than the cost to repair and you can locate the parts. Save yourself the money and take the best option.
My opinion well... I don't really count but, If it was mine. I like to go threw the truck and replace or rebuild everything. Then you start with a like new truck.
When you just get a truck to run things will alway be falling apart till everyting is replaced anyway. The only ex. would be the engine and trans. They would just be inspected.
I hope this helps
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
http://s427.photobucket.com/albums/pp359/oldwestrnwear/?action=view&current=scan0054.jpg sorry im still trying to figure things out but i would like to know how to repair the floor do i cut out the rust and replace the metal with new steel and what about the cab mount brakets there crused and rusted away
wow!i wish my 62 c-60 looked that good and was that straight,i live in central ohio so you can imagine what i have but boy that thing will haul a load of anything, its funny to watch people get outta my way,next best thing to fire truck,i would love to change the cab and doors and a new bed and all that,,,well someday,
