1 members (TexasA&M48Truck),
67
Mod | | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 83 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 83 | I have a picture of an intake/exhaust setup from a '46 Chevy COE. I have put a red oval around what I think is a govenor, can someone verify this for me? If it is...why would you use one of these types of devices? How does it work? Thanks, Chevman Click this link to see the manifold....or just look at the picture here.... [IMG]http://thumb17.webshots.net/t/52/552/3/63/0/2503363000061479077oNundd_th.jpg[/IMG] | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | YES, that is what it looks like. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | chevman, A governor is used to limit the engine speed (RPM) which in-turn limits the trucks speed. On heavy-work trucks, this protects the engine from over-revving under high loads at low speeds. I believe that you are able to remove this device with no adverse side affects (except losing the over-revving protection). Tim | | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | I wouldn't recommend removing the Gov. Most all of these trucks are equipped with very low(slow) Rear Ends. Won't take much over revving to spin a Rod bearing or worse. A well maintained,good working Governor is a must. Just my opinion. The little wheel on the right of your picture should have a seal wire through it. You rotate the wheel to increase or decrease Max. RPM. Use a tach/dwell meter to set at factory spec's. TGP | | |
