0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Just heard of soda blasting on TV. It looks good (Won't warp sheet metal, Environmentally friendly). However, I know from experience is that if something is too good to be true it probably is. Contacted a soda blasting company. He is over 2 hours away and will not charge for travel. He charges $150 an hour, a 3 hour min. I know this is way cheaper than acid dipping. Just looking for input (Good, Bad, Tips, Other Ideas).
Thanks in Advance | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Does your vehicle have rust??? Current condition will pretty much tell you which way to go. I cannot speak for soda blasting but I have had some plastic media work done and it will get off NOTHING but the paint. I think Soda blasting pretty much the same. If there is much rust I go with sand. Do a search on soda, plastic, sand blasting and you will find LOTS of stuff to read and many many points why or when one is better than the other....or why its worst. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Cshamel, I went the soda route, you must be prepared to wash, dry and prime real soon after you soda blast. If you can store the metal parts in a VERY DRY and WARM place you can wait about 2-3 months before priming, but if not prime right away. Look in my link below for what happens if you don't prime, BTW read the notes on each picture. Jake This album is when we picked up the cab from Ill. http://rides.webshots.com/album/414791430bWegiXThis webshots album deals with only soda blasting. http://rides.webshots.com/album/414823796vWvHlXThis album deals with cleaning up the cab with chemical dipping process bcause my friend did not prime as he was supposd to! http://rides.webshots.com/album/418859032XlfpAT | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It only removes paint and dirt, not rust.
My local soda blaster is about 35 minutes away, and last I checked was about $125 an hour. I have had some aluminum stuff and an industrial machine done, but not any sheet metal. I'm very pleased with the results.
I think for a reasonably rust free truck it is a good idea to get the paint off with the soda blaster because it's easy on the sheet metal. Then the next step would be spot blasting the rust as needed with a sand blaster. Likely your "soda blaster" can do both steps for you.
Grigg | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | I have everything shot with glass-bead. It's the best of both worlds- cleans up everything good (rust included) and when done by an experienced blaster, will not warp the metal. I have also had plastic media blasting done, but it doesn't quite get the rust as well. | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | I stay away from soda blasting. It's hard to get paint to stick to the surface afterwards. I stick with sand or glass bead.
Believe me, stay away from soda.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | it's great for antique and vintage aluminum (or really any alloy) motorcycle cases. blasting w/ walnut shells is also a great media for cases.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Jake,
Were you pleased with the job soda blasting did or do you regret it?? | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I was very pleased with it, but the cab was not heavily rusted, UNTIL after my EX-friend left it uncoated in South LA. The fine dust coating can be washed off with water then you dry it right away. Work in front of a big high powered blower and or heater if you can until it is good and dry. THEN prime it the same day or next day and leav the fan and or heater on. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | WHY WOULD ANYONE PUT WATER ON BARE METAL???? JFC!! If that soda won't blow off with air, just use the glass bead like several of us have suggested. | | |
