1 members (dt235sd),
101
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | Does anyone know where to buy dash paint in a spray can? I can have it custom mixed but, If a dealer has it. It will save me time. I am looking for that silver/gold color that was used in the 53 GMC Coe trucks. It was a common color offered. any help, Thanks ahead of time. Email us at [email protected] with info Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Just get one of these .
Bruce | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | After doing a lot of research and having discussions on the GMC forums site: oldgmctrucks.com , we came up with what we believe to be the closest color to the original. I used it on my '51 and '53 as a single stage. You can put a clear coat if you like, but i used as a base with no top coat and it worked fine. The PPG color is: DBU 3898, DK Beige Poly. I think its a 68 Corvette color. Its also the opinion of the GMC site that gmc interior was different then chevys. There are several companys that will take that code and put it in a can for you. Go to my site and take a look at the interior colors and judge for yourself. If you have any other questions on this matter, feel free to contact me. Cecil...........
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Cecil, I came across this post and I have a question for you. I have a 1957 Chevy truck. The top of my dash is black with white "dots." This truck hs been in my family since it was new. My question is was this stock and how would you repaint something like that? Also, is there a code for the gray interior as well as is there a code for the e-brake and steering column? I am sorry if this question is a repeat. I have been searching on Stovebolt and cant seem to find the answer to my question. Thank you for any help! Jon S. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Jon - the "white dots" are from wear and fading [cleaning?], showing undercolor .... the top of the dash was a semi-gloss dark gray called "Charcoal " with no paint code shown on any sheet I've ever seen - the rest of the dash/interior was Marble Gray, original DUCO# 73604 ... the column, support bracket, shifter, ebrake and floor are the same "charcoal" but gloss .... an original 57 dashBill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Thank you Bill, Here is what the Dash looks like, I always that this was stock. Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, just worn out from all that California sunshine and too much work with the dust cloth  you can sorta see on that pic of mine the top is faded out like that too, I think the "primer" below is actually the lighter gray, like they paint the whole thing the light gray, then shoot the top part with the flattened charcoal - I've never found a "correct" current number for that charcoal, but if you get a close match [steering column below the dash] and add some flattening agent, it'll fool your grandad  Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Bill, I forgot to ask what would the color for the steering wheel be? Would it be the same color as the column? It looks like the wheel was a little lighter gray...
Thank you,
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | similar to the column but darker - I've seen'em dark enough to be called black, but not quite, altho that's 58/9's, don't know if that's the year or different plants - most 5-7's [not all!] seem to have been close to the color of the top of the dash, but gloss
Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Maybe I will just keep the column and wheel all the same color, Not sure just yet... Thank you!!! 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
