2 members (MNSmith, Lostbuthaulinass), 105 guests, and 1 robot.
Topics128,057
Posts1,055,814
I have a 1987 and a 1994 chevy PU's. The body on the 94 is perfect. Will the body of the 94 fit on the 87 chassis, or are they just two different animals?
Well that's a little outside my usual area of expertice, but I can tell you that the swap would not be trivial because they are different underneath.
Since the '88 to '98 trucks can now be bought pretty cheap I'm wondering why you would want to swap to the older platform?
I'm imagining it only makes sense if you want a solid axle four-wheel-drive, and the '87 happens to be one, but you may have an even better reason.
That's just it OldSub. I have a solid axle 87 with a good running chassis and crappy body. I have a 94 2wheel drive with a perfect body and paint. I though the 92 might make a good chassis for under a 57 suburban. I guess the point is that I have them, so what can I do with them. I certainly don't want to make a big mess and a lot of extra work if I can help it.
The chassis are completely different. The later trucks have a tapered chassis design, as well as a different cab mounting system. The front bed mount and rear cab mount are 1 peice. Depending on what body the later truck is, there may also be a wheelbase discrepancy.
Bill Burmeister
