9 members (Peggy M, JoeDude, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, Stovebolt48, Donf, 1 invisible),
93
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I have a TAN wire that is disconnected hanging from the steering column. I know it is for the horn. Where does it connect to?
thanks 58GMC | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | the wire leading to the horn ??? just find the horn and its hot lead ,follow it back to its destination. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | It would go to the relay first? I was trying to figure out where in the harness the horn take its power | | | | | Joined: Jul 2007 Posts: 9 New Guy | | New Guy Joined: Jul 2007 Posts: 9 | If you haven't already found this site it is a wealth of knowledge, check it out you'll find electrical diagrams for your vehicle. http://chevy.oldcarmanualproject.com
Ce messam do menmain?
| | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Tan wire goes to the relay. The other two connections on the relay are battery and horn.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I found the plug under the dash and a wire off the ignition switch I think i am good to go now
