4 members (Otto Skorzeny, Hanks custodian, 32Fordpuchoptop, Gdads51), 166 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#488284 12/31/2008 2:28 PM
I have a TAN wire that is disconnected hanging from the steering column. I know it is for the horn. Where does it connect to?
thanks
58GMC
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
the wire leading to the horn ???
just find the horn and its hot lead ,follow it back to its destination.
1952 Chevy Shortbed
Photos in Photobucket
It would go to the relay first? I was trying to figure out where in the harness the horn take its power
Regards,
Lindsay
If you haven't already found this site it is a wealth of knowledge, check it out you'll find electrical diagrams for your vehicle. http://chevy.oldcarmanualproject.com
Ce messam do menmain?
Insomniac
Insomniac
Tan wire goes to the relay. The other two connections on the relay are battery and horn.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I found the plug under the dash
and a wire off the ignition switch
I think i am good to go now
Regards,
Lindsay
