0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have a 1987 and a 1994 chevy PU's. The body on the 94 is perfect. Will the body of the 94 fit on the 87 chassis, or are they just two different animals? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well that's a little outside my usual area of expertice, but I can tell you that the swap would not be trivial because they are different underneath.
Since the '88 to '98 trucks can now be bought pretty cheap I'm wondering why you would want to swap to the older platform?
I'm imagining it only makes sense if you want a solid axle four-wheel-drive, and the '87 happens to be one, but you may have an even better reason.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | That's just it OldSub. I have a solid axle 87 with a good running chassis and crappy body. I have a 94 2wheel drive with a perfect body and paint. I though the 92 might make a good chassis for under a 57 suburban. I guess the point is that I have them, so what can I do with them. I certainly don't want to make a big mess and a lot of extra work if I can help it. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The chassis are completely different. The later trucks have a tapered chassis design, as well as a different cab mounting system. The front bed mount and rear cab mount are 1 peice. Depending on what body the later truck is, there may also be a wheelbase discrepancy.
Bill Burmeister | | |
