4 members (55shaker, Gdads51, 1955 1 Series, 1 invisible), 122 guests, and 3 robots.
Topics128,070
Posts1,055,900
Members48,429
#488123 12/31/2008 3:30 AM
I would like to check and see if my temp gauge is not working or if my sender unit is bad. Also I need to know the correct way to test it and also hook it up. If I am looking at the gauge, does the wire on the left ("C" cold side) go to the accessory side of my ignition switch and the right ("H" hot side) go to the sender, or is this backwards? Any help would be appreciated!
Jeff
There should be 2 wires, one is dark green, the other is pink. The green wire (L) goes to the sender, pink (R) to the ignition switch. However, a '55 should still have a mechanical temp guage, not electric. Electric was a running change in '56, std on V8, I have seen 6 cylinders both ways.
Bill Burmeister
how would I know? The gauge has two leads, I will have to check the colors, but other that that, it looks like all of the ones you see on ebay for sale... so how would I know if it is electric or mechancial and how would I make it match correctly?
thanks so much!!
GMC used electric gauges as early as the 40s if not earlier.
My 1953 Chevrolet
1947.1 Gallery
The mechanical guage has a tube on it that goes to a bulb that fits in the head, which is filled with ether. Since yours has wires, it's definetly the electric. It may have been swapped out at one time, not really a big deal. Mine even has an electric guage in it (not working, burned out on me). From what I can tell from the diagram, the dk green wire (L) connects to the Cold side, and the pink wire (R) goes to the hot side.
rustednuts, I was only speaking for the Chevrolet. I wasn't aware that GMC used electric, though.
Bill Burmeister
