Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
How do I install the window channel felts and wiper in a 58 door
I am thinking that to install the divider felts first.
The window channel would go up against the vent window frame. and down the back of the door. (maybe glue it into place)
Should the window wiper be installed after the door glass is installed?
Does this sound right?
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
There is a tech tip here on the bolt about rebuilding vent windows which will cover most of what you are talking about.
If the window wipers are what I'm thinking you will need to install them while the glass is out.
I'm no authority on the 58's but I think they are like the ones on my 52?. check out the tech tip and see what you think.
Moderated by  ndkid275, Phak1
