0 members (),
187
0
Mod | | | Forums66 Topics128,274 Posts1,058,425 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | How do I install the window channel felts and wiper in a 58 door
I am thinking that to install the divider felts first.
The window channel would go up against the vent window frame. and down the back of the door. (maybe glue it into place)
Should the window wiper be installed after the door glass is installed?
Does this sound right? | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | There is a tech tip here on the bolt about rebuilding vent windows which will cover most of what you are talking about.
If the window wipers are what I'm thinking you will need to install them while the glass is out. I'm no authority on the 58's but I think they are like the ones on my 52?. check out the tech tip and see what you think. | | |
