4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#485602 12/23/2008 6:44 PM
Apprentice
Apprentice
I am trying to figure out if there is a difference in the size of the gasket between a 1 ton and my a ton and a half. If there is can someone please tell me where i can find one for my truck. Thanks
EMS is my life. But I have found my TRUE PASSION OLD TRUCKS...
Consider using a compound designed to replace gaskets, made by Permatex and called "The Right Stuff". This is not silicone but a rubber type material. It comes in pressure can and also in a tube designed for your household caulking gun. It is a little pricey ($20 for the tube) but you get multiple uses from it. I have used it on the differential cover and rear axle cover on my '50 Chevy COE and on the oil pan on my Diamond T. It is so easy to use with the caulking gun and so far no drips or even seepage. I was told by the truck parts store that made me aware of it, that it is OEM on certain Caterpillar oil pans. The directions say that you can put the vehicle immediately into service after mounting the part.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
3B Offline
Hy Bubba the Emt, please remember to tell us what year of truck you are asking about in your posts, that way we don't have to go and check your profile to find out what you're asking about. Fel-Pro numbers for the cover gaskets are, for single speed rear end RDS 4062, for two speed rear end RDS 5050, and they are not the same as one ton gaskets, hope that helps.
Apprentice
Apprentice
Sorry about that. My mistake and yeah it does help now im trying to figure out if I have a single or two speed axle.
I have a 1946 1 1/2 ton and was able to get one finally from NAPA after the second try, Maybe your local store will be better.
H Online: Content
Depending on the year model, a 2-speed axle will have an electric motor or a vacuum diaphragm near the pinion flange, where the driveshaft attaches to the rear end.
I had a heck of a time finding a compatible gasket for mine, and it wouldn't stop leaking w/o gasket sealer. I finaly gave up and used the previously mentioned "right stuff" with no gasket. Haven't lost a drop since!
Now my transmission is another issue,... :P
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Apprentice
Apprentice
Guess I have a single speed cause theres no motor or visible vacuum line.Thanks for the helpful tip HOTROD.. THank you LIghtholders DAD the RIGHT STUFF WORKS AWESOME!!!!!
24601
Wow -- Could have used that stuff last fall... looks like neat stuff.
For anyone else interested, here's the Permatex web site for "The Right Stuff"
Thanks for the tip, lightholder's dad!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
