4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#48729 08/07/2005 3:55 AM
Does a 56 Chevy 3200 use a 2-piece driveshaft with a center bearing or just a straight 1-piece? No driveshaft in our new toy. Also what manual transmission (prefer 4-speed) should we look for that will fit well with the stock driveline?
Gene & Jr
horseballz
'56 Chevy 3200
'69 Ford F250
'68 Mustang Coupe/5.0 Roller/T5/Factory A/C
'03 Miata (Wifes Ride)
the TF long box is just a longer single shaft [pre-'66 coarse tooth in the yoke] - the 3/4T and up have the 2 piece, and therefore has an extra cross member w/ the center mount for the shaft - the 4 speed that will fit right in is the original SM420, same for many years, but unless you're really workin the truck at slow speeds, the 3 spd is just as good - of course if you have no trans in it maybe it also doesn't have the column shift on it
Junior Member
Junior Member
I have a 56 3200, it's a one piece driveshaft. I have a 3spd on the tree
Riding in the Passing Lane
I have a 55 II & like Ktech says it,s a one piece. Now would be a good time to put a T-5 five speed with o,drive in it & have a drive shaft made up for it. The tech tips has a good coverage on this & there have been many posts. You can do a search & get plenty of info. smile
1972 Chevy c10 Cheyenne Super
