8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian),
66
Mod | | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48729 08/07/2005 3:55 AM | Joined: May 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: May 2002 Posts: 30 | Does a 56 Chevy 3200 use a 2-piece driveshaft with a center bearing or just a straight 1-piece? No driveshaft in our new toy. Also what manual transmission (prefer 4-speed) should we look for that will fit well with the stock driveline? Thanks, Gene & Jr
horseballz =========== '56 Chevy 3200 '69 Ford F250 '68 Mustang Coupe/5.0 Roller/T5/Factory A/C '03 Miata (Wifes Ride)
#48730 08/07/2005 5:24 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the TF long box is just a longer single shaft [pre-'66 coarse tooth in the yoke] - the 3/4T and up have the 2 piece, and therefore has an extra cross member w/ the center mount for the shaft - the 4 speed that will fit right in is the original SM420, same for many years, but unless you're really workin the truck at slow speeds, the 3 spd is just as good - of course if you have no trans in it maybe it also doesn't have the column shift on it
Bill | | |
#48731 08/08/2005 7:28 PM | Joined: May 2005 Posts: 12 Junior Member | | Junior Member Joined: May 2005 Posts: 12 | I have a 56 3200, it's a one piece driveshaft. I have a 3spd on the tree | | |
#48732 08/08/2005 9:44 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have a 55 II & like Ktech says it,s a one piece. Now would be a good time to put a T-5 five speed with o,drive in it & have a drive shaft made up for it. The tech tips has a good coverage on this & there have been many posts. You can do a search & get plenty of info.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
