1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48712 08/05/2005 10:30 PM | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | So, as you all know, finding 8 lug 16" wheels with the correct backspacing can be a very difficult task. I finally gave up, saved my pennies (a LOT of pennies), and had Stockton Wheel make me a set for my 3800 panel. I waited about 5 weeks for delivery and ordered up 2 215/85/16 for the front and 2 235/85/16 for the rear.
About a week ago I started having second thoughts and doubting myself... "Did I say 2-1/2" backspacing or 3-1/2"?" Don't you hate it when you second guess yourself? I checked back in with the 'Bolt forums and verified that 3-1/2" was what seemed to be the answer.
Sure enough, they showed up and were 2-1/2". I thought "what the heck... let's find out" and had the tires mounted anyway. This afternoon I bolted 'em on and everything looks pretty good! It has a little wider stance and the 235's in the rear really fill out the fender nicely! Right on the front edge of the fender they are pretty close tho. Do you guys think that about 3/4" is enough clearance between front edge of tire and fender? If it's going to be a problem, I guess I could just trade the 235's for 215's and gain a little room that way. The front wheels have loads of clearance through their full travel and are WAY off the steering linkage. Anything ELSE I should watch out for?
I may be the only guy on this site who wishes he had a little MORE backspacing on his wheels. Just thought I'd check in with the latest chapter in my neverending project.
-Joel
Oh... I'll be putting my old 17" splits in the swap meet if anyone's interested.
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
#48713 08/07/2005 4:26 AM | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | How about some pics? Sounds great . . . | | |
#48714 08/07/2005 5:27 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | 3/4" should be enough clearance but if the tires rub you can add a sway bar and take care of that problem. | | |
