Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (ShopRag), 122 guests, and 5 robots.
Topics128,281
Posts1,058,471
Members48,490
#486980 12/27/2008 10:45 PM
I also forgot. Can i also adjust the play in my steering thru the steering box?
Cheers
Tim (UK)
Riding in the Passing Lane
Yes but first find out where the play is. Have someone move the steering wheel back & forth while you look underneath. The wheels must be straight ahead.Often the play is in the drag link. If the gear needs acjustment loosen the lock nut on the side of the steering box. Some have a lock tab to pull back. Screw the adjusting screw in till it starts tightening up. Tighten the lock nut & turn the wheels back & forth to check for binding. If it binds going across Or near center back the adjustment up a little. If it still has play you will have to remove & o-haul it.
1972 Chevy c10 Cheyenne Super
Get a fish scale and do this.
thanks for your help guy's. i will check it out at the weekend.
regards
Tim
