0 members (),
145
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | I also forgot. Can i also adjust the play in my steering thru the steering box? Cheers
Tim (UK) | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes but first find out where the play is. Have someone move the steering wheel back & forth while you look underneath. The wheels must be straight ahead.Often the play is in the drag link. If the gear needs acjustment loosen the lock nut on the side of the steering box. Some have a lock tab to pull back. Screw the adjusting screw in till it starts tightening up. Tighten the lock nut & turn the wheels back & forth to check for binding. If it binds going across Or near center back the adjustment up a little. If it still has play you will have to remove & o-haul it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Get a fish scale and do this. | | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | thanks for your help guy's. i will check it out at the weekend. regards Tim | | |
