0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48575 08/02/2005 3:45 AM | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | my 235 is at the machine shop now, I would like to get several choices on a good cam to run, truck will be kept mostly stock, 1 barrel carter "yf" carb, stock exhaust manifold, 3 speed on the column, with stock 4.11 gears.
would you advise a solid lifter cam, or a hydralic?
the 235 is a '59 model passenger motor that had a hydralic cam, what would have to be changed to run a solid lifter cam? are the push rods & rockers different? | | |
#48576 08/02/2005 4:29 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I would go with the solid lifter cam. The 235 really doesn't have the oil pressure to keep the hydraulics happy. You will need new pushrods and of course lifters. Everything else will work unless you go with a more radical cam. Then you will need stronger valve springs. Give Patricks a call. He will be glad to share his opinions on this topic with you. He has some strong arguments for going solid. | | |
#48577 08/02/2005 5:02 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | You can also use a 261 cam, which of course is a solid lifter cam. It is almost identical to the mild cam Patrick's sells, but a lot cheaper (I got a new, not reground, one for arount $110). You can also use stock lifters, pushrods and valve springs with it. Makes my 235 run quite nicely.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#48578 08/03/2005 12:40 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Well I'm going to be different and for what is to me a very good reason; your talking about a totally stock engine otherwise, correct? So why not use the hydraulic cam and lifters and save yourself all that noise, adjustment and expense. The solid lifters will not gain you a single thing. The only reason in using them would be to take advantage of some performance goodies which you are not using as I understand it. And don't let anyone tell you that a six banger oil pump doesn't have enough pressure. Mine runs 40 lbs +. | | |
#48579 08/03/2005 3:14 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | And don't let anyone tell you that a six banger oil pump doesn't have enough pressure. Mine runs 40 lbs +. Well excuse me! I have heard this a 1000 times from various mechanics and old inliners. I guess if you have a brand new pump or a high volume pump it might help. My oil pressure is 30# and goes down to 10-15 at idle. Guess I need a new pump or go to straight 30 oil. | | |
#48580 08/03/2005 6:00 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | One major drawback to the hydraulic lifters-cost. IIRC they were at least 3 times the cost of solids. I've also heard that the design of the hydraulics didn't allow for efficient "burping" of air, and would therefore sometimes get air bubbles. The bottom line is to make an informed decision and do whatever makes you happy.
#48581 08/03/2005 7:53 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The hydraulic lifters are not plumbed to an oil gallery, so don't have access to full oil pressure anyway, they just need a continuous supply of oil. The early hydraulic lifters just weren't that great, but got the job done.
Baldy | | |
#48582 08/04/2005 7:46 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'd go with the hydraulic set up;less maintenance,quieter,and to a certain degree,oil pressure isn't really a factor.as long as you have enough oil pressure at idle to keep the lifters from collapsing (10 lbs should be plenty) and enough volume to keep everything wet,the hydraulics should be fine. If your lifters start to collapse at idle,it's time to pull the engine down for bearings and a new oil pump anyway. | | |
