8 members (Tronman, Wally / Montana, David Bush, 1955 1 Series, klhansen, Hotrod Lincoln, Gray_Ghost, Peggy M), 68 guests, and 3 robots.
Topics128,051
Posts1,055,714
#484799 12/21/2008 5:02 PM
55 First series. The temp sensor looks to be a hard copper line. Helen has a 283 V8 in her. Can the copper line be extended?. or is there a replacement that is longer, with out replacing the guage itself?
Thanks in advace
Project Helen,
The temp gauge is indeed a sealed system and cannot be broken into or extended. The hollow tube is filled with ether and must remain attached to the gauge and leak free to work.
I would think your options would be to find access to the water jacket in an area that the stock system can reach, see if after market suppliers make a 'faux' stock electric gauge or a gauge with an extended tube.
There must be a good answer to this because there are a million SBC transplants into these AD rigs all the time.
Stuart
Another option would be to send the gauge and line to a gauge rebuilding service and have them attach a line with the appropriate length and proper connection. Try Hemmings or do a search here. I used Bob's speedometer service for my Diamond T and was very satisfied (the gauge now reads within 2 degrees of our kitchen thermometer---oops, don't ask my wife how I know that!!).
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
