| | | Forums66 Topics128,162 Posts1,056,944 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48325 07/27/2006 3:19 AM | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | I was curious as to what type axle was in the back of my 68 Chevy 3/4 ton truck. It doesn't look like a 12 or 14 bolt.. Could it be a dana 60 or something? What was installed from the factory and what gears would be in it. It came with a V8 and 4 speed with granny low. Thanks for the help.
~Joe | | |
#48326 07/27/2006 4:50 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The center section looks big and round from the rear? Its probably the same rear used in 3/4- and 1-ton GM trucks since the AD trucks.
Can you post a picture?
The later year rears have better gears than the early ones, but with a 4-speed it is not likely the most desirable ratio usually only found on automatic equipped trucks.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#48327 07/27/2006 11:03 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s GM own make. It has a drop out center section & a rear cover. It probably is 4:11 ratio. It could be 4:55. There were some 390s but I understand they are pretty rare. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48328 07/27/2006 11:41 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Most likely it's an Eaton, though there some that had either Spicer 60/70 differentials. So far I've only seen them in Camper Specials in Chevies. They were standard in GMC.
Bill Burmeister | | |
#48329 07/28/2006 4:04 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The rear axle that was in my 68 C20 with 327 and a SM465 was a Dana 44 with 4:56 ratio. I replaced it with a Dana 60 out of a 73 with a BB and an auto that had 3:73 gears. Here's a rear axle identificaion site. http://coloradok5.com/axleguide.shtml Larry
I don't own a vehicle that isn't old enough to drink. | | |
