4 members (wilbur53, carbking, Dennys28, Southerntruck), 65 guests, and 0 robots.
Topics128,156
Posts1,056,870
Members48,456
#48325 07/27/2006 3:19 AM
I was curious as to what type axle was in the back of my 68 Chevy 3/4 ton truck. It doesn't look like a 12 or 14 bolt.. Could it be a dana 60 or something? What was installed from the factory and what gears would be in it. It came with a V8 and 4 speed with granny low. Thanks for the help.
~Joe
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
The center section looks big and round from the rear? Its probably the same rear used in 3/4- and 1-ton GM trucks since the AD trucks.
Can you post a picture?
The later year rears have better gears than the early ones, but with a 4-speed it is not likely the most desirable ratio usually only found on automatic equipped trucks.
#48327 07/27/2006 11:03 PM
Riding in the Passing Lane
It,s GM own make. It has a drop out center section & a rear cover. It probably is 4:11 ratio. It could be 4:55. There were some 390s but I understand they are pretty rare.
1972 Chevy c10 Cheyenne Super
#48328 07/27/2006 11:41 PM
Most likely it's an Eaton, though there some that had either Spicer 60/70 differentials. So far I've only seen them in Camper Specials in Chevies. They were standard in GMC.
Bill Burmeister
The rear axle that was in my 68 C20 with 327 and a SM465 was a Dana 44 with 4:56 ratio. I replaced it with a Dana 60 out of a 73 with a BB and an auto that had 3:73 gears.
Here's a rear axle identificaion site.
http://coloradok5.com/axleguide.shtml
Larry
I don't own a vehicle that isn't old enough to drink.
